Can't publish library when switching from team to organisation
  • January 30, 2025
  • 27 views
Maite_Who
I found this weird bug where when a library has been published in a team, it can’t be published to the whole organisation without making a change in the library.
In the publish library pop up the “publish” button stays disabled when I switch to organisation in the “publish to...” dropdown
If I make a “fake change” (change a color and change it back, then the publish button is active)
Expected behavior:
When I change the access of the library I expect the “publish” button to be active even if no change has been done to the library.
  • 2422 replies
  • February 4, 2025
Hi ​@Maite_Who ,
Thanks for reaching out. I'm checking with our internal team. I will get back to you when I have anything I can share with you.
Thanks for your patience.
