how to check, uncheck and hide a component in figma with variables
  • January 28, 2025
  • 43 views
tara_singh1
https://www.figma.com/design/xcXqeTMQOUpu5cAf43jExS/input-field-Filters-with-Variables-in-Figma---Video?node-id=0-1&t=l5zwMTgD5XEl9sT2-1
I have created rows and if user select any row basis on that counter will run and delete button will apear. My query is If i selected any row then by clicking on the delete button how can delete a row and counter should change into - (decreasing form).
kindly help me.
Pavel_Kiselev
  • 438 replies
  • January 28, 2025
Here is what you can do
it’s for single select list, which you can turn into multi select one. You can make the counter a part of you list component or you can have it separate and bound ‘selected’ to a text layer contents
tara_singh1
  • 5 replies
  • January 28, 2025
@Pavel_Kiselev i did it in the same way but my query is how can i delete a selected row or rows.
