Unable to edit font styles
  • January 25, 2025
  • 4 replies
  • 58 views
TheCommonTiger
I’ve been trying to edit a font style in Figma and the changes are not applying.  How can I get it to work?
I’ve edited the font multiple times, and don’t see the change reflected in my selected instance or other instances. I’ve tried quitting and restarting. I’ve also tried applying a different text style, but the font doesn’t change then either.
Avokadomos
  • January 25, 2025
You’re not using a standard font. Does it work with other fonts?
TheCommonTiger
I tried applying Arial and Helvetica manually, and they applied. I also tried applying this same non-standard RocaOne-Hv font manually, and it applied. I also tried applying other font styles, and they applied. However, when I go back to applying the “Page Header” type style, it fails to apply. Something is wrong with that style, and one other in my collection.
Avokadomos
  • January 25, 2025
I managet to get the same state as well. I’m trying to apply the text style, but it stays with the previously selected.
When the text style has that T icon, it indicates that it can’t render the font for some reason. In my case, it was because the style was set to bold even though the font itself doesn’t support that weight. Try opening the weight dropdown and select anything that’s available.
TheCommonTiger
I ended up deleting the broken font style and using my others that work, but I’ll try it if I get that problem again. Thanks for the feedback!
