Text exported as PNG does not have the same width and height that text that in the figma file
  • January 24, 2025
  • 21 views
a23Marcos
Hello, I spent some time trying to find a response in existing question but wasn’t able to.
Here’s my problem: I have a text object that would show 593x89 (width and height) in the properties panel.
But, when I export the element to PNG, the file I get is smaller (cropped) 587x61 px
The exported file is used to create HTML code to replicate the figma file, so when we set the asset to the same position that in the figma file (e.g. top: 219px, leftL 56px), it’ll look off position, because of the missing “padding”. Here is the exported “cropped” asset on top of the original image:
Is there a way to export the asset with a size matching the figma object, or to find out the “cropped” top and left pixels so it can be added to the top and left position?
Thanks a lot in advance
Avokadomos
  • 377 replies
  • January 25, 2025
Wrap the text element in a frame and then export the frame instead.
a23Marcos
  • January 27, 2025
Thanks for the reply Avokadomos, makes sense, however, I would like to solve this issue without modifying the figma file as in many cases the tool we are building needs to be used in figma files we do not own
a23Marcos
  • January 27, 2025
Ok it was simpler that what I thought; the boundingRect property of the layer can be compared with the asset size to determine the appropriate offset.
