Variables from published library aren't available in the new project
  • December 18, 2023
  • 7 replies
  • 2075 views
Yuri_Ryzhenkov
Hello there. Shortly problem is that published variables are not available in the file where i enabled this library.
Steps:
  1. Published a library with two color variables (and two color modes)
  2. Enabled library in empty project
  3. Made a rectangle and tried to apply a variable
Results:
On first iteration i was able to apply a variable on rectangle. When i’m trying to change it, it doesn’t show the second variable.
On second iteration (the same steps) it went well and i don’t know why. I am able to switch between variables.
On third iteration i’ve tried to publish big library with 238 variables. In project file 0 variables appeared.
I have files from each iteration, so Figma support guys, you are welcome to investigate it.
Best answer by Yuri_Ryzhenkov
Problem solved. The issue was in variables with state “Hide from publishing”, a lot of them have been disabled in imported library from “Untitled UI” by unknown reason.
Arkadiy
  • December 18, 2023
Similar issue
Sergey_Tomashevsky
The same problem. It is not clear how to publish variables.
Celine_D
  • 3418 replies
  • December 19, 2023
Hi there!
Sorry to hear you are having issues publishing your library.
To cover some basics, here’s a guide how to publish individual styles, components, or variables: https://help.figma.com/hc/en-us/articles/360025508373-Publish-a-library#individual
If you are still running into issues, I’d recommend you to reach out directly the support with a copy of your file (where the library is located) and share a quick screenshot / video recording when the issue happens here: https://help.figma.com/hc/en-us/requests/new. This will help our team to investigate and replicate it. Thank you!
Yuri_Ryzhenkov
Celine_D
  • 3418 replies
  • December 29, 2023
Glad you’ve found a fix. Thanks for letting us know!
Julia_Mnizhek
  • 16 replies
  • May 22, 2024
Faced same problem recently. We have created several variable collections in our tokens library, none of them are hidden, but in the files where we apply this tokens library we see only one collection and cannot see the others.
_fay
  • December 17, 2024
this issue has been daunting me for a few weeks now, thank you for coming back and replying with the solution.
