Using Google Analytics in a Figma Plugin
  • January 7, 2022
  • 12 replies
  • 5271 views
Miranda_Bailey
Hi everyone,
I’m trying to use Google analytics in my Figma Plugin to track usage. I get the following Security error when Google Analytics is initialized.
‘SecurityError: Failed to read the ‘cookie’ property from ‘Document’: Cookies are disabled inside ‘data:’ URLs.’
Has anyone had any luck with using a analytics solution inside your plugin ?
Thanks!
Matthieu_Lepine
Up ! Interested by this topic 🙂
Miranda_Bailey
@Matthieu_Lepine I was able to use mixpanel for this. Check out mixpanel-figma - npm
Andrew_Fiorillo
I’m also very interested in this.
Erwin_Goossen
But are we getting a cookie insent message first then? Or do you get notified about the fact you’re using GA? This because I’m not quite sure how this will work with GDPR
Aman_Jha
  • September 14, 2022
this worked well for me! recommend for others.
Paulo_Henrique_Abreu
It’s worked well for me too! 😀 Thanks!
Jose_Luis_Gonzalez_Jimenez
I wanted to track the plugin analytic and I was playing with mixpanel-figma - npm as well. I also made more advances tracking with New Relic. Take a look to this article if you want to know more How to get analytics and observe your Figma plugin behavior
dachan
  • March 13, 2023
Is mixpanel-figma still working for everyone?
I keep getting a TypeError: cannot read property 'console' of undefined when loading the plugin after adding:
mixpanel.init({myToken}, {
  disable_cookie: true,
  disable_persistence: true
jk2K
  • April 9, 2023
I want this feature, who knows how to use Google Analytics 4 in a Figma plugin
@Miranda_Bailey how did u set up GA4 in the first place, can u help me out
Angga_Putra_Sundowo
Still working for me, I also had the same error, then I moved this init function inside the UI entry file not inside the code entry file, it has the console window function running once triggered.
  • October 3, 2023
Hi @Miranda_Bailey do you have instructions on how to connect Google Analytics to Figma prototype?
