Zara_Pokrandt
Jul 24, 2023 7:35 PM UTC
Unable to publish 1 change to the Team Library - 2.0
I am reaching out for assistance with a problem I’m facing while trying to publish my component library.
Currently, I’m encountering the error message “Unable to publish 1 change to the Team Library.”
To troubleshoot the issue, I followed a systematic approach and discovered that the problem lies with a specific component, component A.1. Surprisingly, when I removed component A.1, I was able to publish component A without any issues. I carefully examined component A.1 for any potential problems, but couldn’t find anything amiss, and I managed to publish it successfully as an individual component.
However, the problem persists once I reintroduce component A.1 back into component A.
As a detail to note, all the required fonts are available within the components.
I would be extremely grateful if anyone from the community could provide insights, solutions, or suggestions on how to overcome this obstacle and successfully publish the entire component library.
Thank you all in advance for your valuable assistance!
Jan 24, 2024 6:37 AM UTC
Faced a similar issue almost 9 months from when you did and found a solution.
Following the same analogy as yours, my component A.1 had an instance of component A. This instance was hidden and went unnoticed. As soon as I got rid of this instance creating an infinite loop. Everything became good to go.
Hope this works for you an others.
Jan 25, 2024 5:35 AM UTC
Hey, Thanks for reaching out for the error message “Unable to publish 1 change to the Team Library.”! I understand how you feel and appreciate going through those troubleshooting steps!
Thank you so much for sharing your experience and advice, @Abutalib_haider !
If there are local Fonts used in those Components installed, please check along Abutalib_haider’s advice and see if it helps!
Here are related article might be helpful: Publish individual styles, components, or variables
Hope it helps! If it doesn’t, could you please reach out to our support team directly here?:https://help.figma.com/hc/en-us/requests/new
Please include:
  • The URL of the file, and add support-share@figma.com as an editor on the file.
  • The link to the library you’re having trouble with
  • Also, confirm that you already have local fonts installed and you’re happy for our support team to test publish on your behalf.
Thank you!
Deluko
Nov 5, 2024 3:17 PM UTC
Wanted to share in case it helps anyone else:
I was getting the same error when trying to publish, and it was “failing” on 7 text styles – it didn’t indicate why.
Turned out I had a missing font, so after inspecting the various unpublished text styles, and resolving the missing font issue (installing the font), I was able to publish the changes without issue.
