Toggle text input panel with dropdown ON an overlay
  • May 31, 2024
  • 173 views
Ian_Higgins
Hey all. I have an overlay dialog full of settings. There is a dropdown with two options. I would like the second option to enable a text input field next to the dropdown (and similarly, the first option should disable it).
The dialog is an overlay. The dropdown is a component with an overlay for content selection.
How do i enable/disable the text input without it screwing up the overlay?
  • Figmate
  • June 3, 2024
Hi @Ian_Higgins, Thanks for reaching out about your prototypes using overlay.
I’m doing my best to understand what you’re aiming for, but I’m not entirely sure if I’ve got it right. One suggestion might be to use conditionals to enable or disable based on the options you choose.
Here are some resources that could be helpful:
If that doesn’t quite help, feel free to explore resources in our community on your own. You may come across a design file that inspires you! :https://www.figma.com/community/
As another option, if it’s not too much trouble, could you consider sharing some screenshots or recordings with our community? This would provide a clearer visual understanding and might also increase your chances of receiving some helpful advice from our experienced members.
We’re always open to hearing additional suggestions for this from our community. Please feel free to share!
Thanks again for reaching out.
