Toggle Show/Hide UI not working on Windows since Ctrl + can not be pressed
Aleksander_Klajderic
At least on European keyboards (don’t know about the others) there is no dedicated backslash button. Therefore I can not use Ctrl + \ to show or hide the UI of the Figma web app.
Keyboard combinations with Alt are not working.
If I hide the UI with the help of the menu, I can not Show it again since the menu is part of the UI. !!??!
Finch
  • 15 replies
  • February 11, 2021
Ctrl + P is a universal shortcut you can use to bring this menu up as an alternative to Ctrl + \
  • 4708 replies
  • February 11, 2021
Ctrl + P is for Ctrl + /, not Ctrl + \. The other alternative to Ctrl + \ is Ctrl + . (dot). And you can create custom key bindings on windows using Auto Hot Key or similar apps. I use Better Touch Tool for that on Mac.
Finch
  • 15 replies
  • February 11, 2021
Derp! You’re right, I’ve mixed up my slashes.
I’ve got CMD + . on Mac, would have to check my windows machine.
If you click the ? icon in the bottom corner you can see all the keyboard shortcuts.
great, now I can at least get the menu back.
Eric_Ferole
You can right click on the background beside your canvas to access the menu to hide or reveal the tools panel.
Oh boy… perfect!
lea_delazer
Try cmd + # (the key with ’ and # near the return key) , this works for me on my European keyboard.
I said Windows.
Marci
  • 14 replies
  • February 17, 2021
@Aleksander_Klajderic There’s no EU keyboard, but plenty of different keyboard layouts worldwide. Every layout has a different key combination to show/hide UI.
Check these shortcut cheat-sheets and if your keyboard layout is missing, let me know and I can try to add or at least tell you how to show/hide ui.
👉 www.ui-kit.co/shortcuts
Alex_K
  • 10 replies
  • March 25, 2021
You might want to upvote this feature request: Customizable shortcuts
Marek_Gebka
Hey, at least on a german keybord for me it is CMD + .
Aly_Colomar
I’m using Figma on Windows on a european keyboard, try Ctrl + * to hide and show Ui
Lea_Davoine
thank you for this !
Flow_Gurus
To hide and show UI for Mac users:
fn + Command + \
This atm hides and shows the UI for me.
Jerome1
  • July 20, 2021
For information on my european keyboard (AZERTY) on Windows the shorcut to show/hide UI is Ctrl + ;
The key between the , and the :
bengala
  • July 26, 2021
In México the shortcut in Mac is + Ç keys, maybe it should work for someone else 😉
David_Alehandro
I’ve been looking for this answer for months!!!
GRACIAS!! 🤩
Simon_Vandereecken
For the Frenchies, the cmd + `
Juan2
  • August 10, 2021
@ bengala That works in Spain, thanks a lot 🙌
bengala
  • August 10, 2021
Glad it helped. ☺
Blanca_de_Santiago_Saez
what works for me to show/hide UI in Spanish mac keyboards is cmd + .
Teppo_Kotirinta
Thanks this was amazing tip. I’ve tried to use macOS Keyboard hotkey overrides to make some hotkey work for Show UI on Finnish keyboard. But somehow Figma doesn’t respect macOS-specified app-hotkeys, so nothing has worked.
But CMD + . does indeed work to Hide/Show UI. Thanks!
Pedro_Casara_Luz
For Brazilians/Portuguese who were googling this:
Just found that in PTB/PTB2 keyboards it is Ctrl + ]
Para os brasileiros/portugueses procurando, o atalho para Show/Hide UI em teclados PTB/PTB2 é Ctrl + ]
maria.alvarezserrano
For me (German keyboard) the Figa UI hides/shows up with Ctrl + ^ (the key right next to the 1). As I am using a german keyboard, it is actually Strg + ^
Carlos_Gallo
Thanks paul
