Andre_Cassal
October 7, 2023
Swapping and configuring instances via setProperties result in weird results
  • October 7, 2023
  • 292 views
I have a component which has different variant as well as boolean and text properties, when I set values via API using instance.setProperties and the object passed changes the variant of the instance
Code example
figma.currentPage.selection[0].setProperties({
    "Text#48:1": "$20.4",
    "Color": "Black",
    "hasSalesPrice": "True",
    "StrikeThrough Text#48:4": "$68"
the problem is that changing the variant and text properties at the same time doesn’t seem to be working.
any thoughts?
tank666
October 8, 2023
Do you see any errors in the console?
