Paul_Peeters
May 7, 2024
Spacing Problem with Prototype: On click hide and arrange Auto Layout elements
  • May 7, 2024
  • 634 views
Hi,
I feel like I have a problem, that should be relatively common with people creating prototypes. In general its a straight forward thing I want to achieve:
  • I have elements in an AutoLayout
  • When I click Element A, it should disappear and the other elements should move up
  • When I click Element B, it should disappear and the other elements should move up
  • And so on
The Problem:
  • The Layers don’t “really” disappear (I have set the height to 0.00001), so that i have a shift in the prototype every time I click on an element.
What I have found in the forum as solution to set a height of the element, that should disappear to 0.0001, but as described this doesnt really work.
This is a functionality, that is so common in everyday apps and software, that I am wondering if I am missing something?
Best answer by Junko3
Hi @Paul_Peeters, Thank you for reaching out and taking the time to explore our community! I really appreciate your engagement.
I’ve done some testing on my end, and it seems that setting the height to 0 works.
Could you please double check the Auto layout properties? Below are the settings I’m using for your reference. You can find more details here: ​​Explore auto layout properties
Additionally, I explored our community and found related design file which might inspired you: Auto Layout Tips & Hacks
I hope you find this helpful! If there’s anything else I might have missed, please let us know. Also, if anyone else in our community has further insights or tips, please feel free to share!
Junko3Solution
Paul_Peeters
May 10, 2024
[EDIT] → It now works with the line → frame → delete line hack! Thanks again!
Hi Junko3,
thanks so much for the response and also the attached Tips&Hacks file. This is exactly the problem I am having and in your example video you have the solution I need 🙂 .
I actually tried the approach to just set the variant to 0 as well as the hack with creating a line, frame it, delete the line. For some reason I still get the unwanted space for each item clicked. This is my process:
  • create a rectangle
  • create the line, frame it, delete the line
  • make a component set of both
  • set a on click event to change the state to the empty frame
Is there something you have been doing differently?
Thanks so much!
Paul_Peeters
May 10, 2024
Also a little “bug” I discovered:
Since I wanted to have a spacing between the elements I originally set the spacing inside the autolayouted frame. With this, the spacing “bug” will be there again.
As a solution I set the spacing to 0 and added a margin in the original component variant. This way it works.
