The Slides file is in the same space with my design system files but I cannot see my published colours and text styles within Slides. Is this a known issue or am I missing something?
Shared library does not appear in Slides
Best answer by y_toku
Hi there,
Thanks for reaching out. To use library in Slides, you need to add. Let me share how to do so.
Add a library to your slide deck
- Click Assets in the toolbar.
- Click Add your own.
- Enter the library name in the search field or browse through libraries available to you.
- Click Add to file.
If a library you added includes styles, you can apply styles to objects in your slides. Accessing styles differs depending on which Figma Slides mode you’re using.
If you’re using design mode, accessing styles works the same way it does in Figma Design. Learn more about applying styles to layers and objects →
If you’re using slides mode, you can access the following style types:
Text styles
- Select a text layer.
- Click the Text style dropdown in the right sidebar.
- Click Apply styles to view a list of available library text styles.
Color styles
- Select an object with a fill or stroke.
- Click the Fill dropdown.
- Do one of the following:
- To add a template color, click the plus next to Template colors
- To add a color outside of the template colors, select Add color below Others in this deck
- Select the Libraries tab to view a list of available styles.
Here is more details on this:
Figma Learn - Help CenterI hope this clarifies the thing, but please feel free to let us know!
Toku
