Aug 30, 2023 2:05 PM UTC
Set Auto Variable Mode Default
I created a collection and have Light and Dark modes within. Dark mode is first when looking at it from left to right, and all the auto defaults are in Dark mode. How can I switch this to Light mode?
I don’t see any option for this.
MEEfO
Oct 5, 2023 12:03 PM UTC
Did you ever find an answer for this?
layercakeAuthor
Oct 5, 2023 2:10 PM UTC
Unfortunately no. Still annoying I have dark mode as default.
Martin23
Jul 5, 2024 11:20 AM UTC
Hey @layercake . I struggled with the same issue and found a way around it. Figma obviously takes as “Default” whichever Mode column comes first in the Varaibles UI. I assume your dark mode comes first then. Solution:
Right click on Dark mode, and make a copy of it via duplicate. Your columns will be then darkmode-lightmode-darkmode(2) . Now delete the first original darkmode and rename the copy to jus Dark mode. Your table will then look like light mode-dark mode. Hence the. default will change to light without loosing any hard work you put in defining the hexcodes.
Shameer_Purayil
Sep 19, 2024 7:35 AM UTC
this method worked for me… good job Martin
