Right Side Bar disappeared
Yulia_Sokolova
My Right Side Panel Menu disappeared! HELP! Control+\ does not bring it back!.
JanKragh
  • 77 replies
  • April 26, 2022
If the UI is hidden, use mouseclick to go to contextmenu, select “Show/Hide UI”
ezichi_gift
This is not working either
Emilie_Oswald_Macaulay
I’m having the same issue. Have you found a resolution?
Flavio_Lee_Budoia
This is a browser issue. So, if you’re using Chrome, switching to another browser solves it. Probably using the app instead also would do the trick.
No clue about why it happens, though. =/
Just happened with me and going with Safari was the only solution.
Probably updating Chrome should fix it.
Moeslein_Michael
I’m having the same issue in the browser. I can hide/show the bottom tool bar, but nothing will bring back my left and right panels.
pkp
  • 29 replies
  • November 15, 2022
SInce this is a really old issue I would recommend you the same as mentioned in previous comment try updating your browser. Or try in incognito may be some cache issue. Better download figma application.
  • February 25, 2023
This just saved my life lol. Thanks for that. Another shortcut that I MUST memorize lol.
Mine worked when I logged out and logged back in.
Swikar_Ramdam
Go to view>panels>show leftbar
This happens when you accidentally zoom the browser window. In chrome, go to View > Zoom Out, or View > Actual size.
From there you can toggle the panels on / off as normal using Command + \
  • October 9, 2023
  • April 11, 2024
All the tools on the right hand side were missing, for me, it was because the ‘New file’ button doesn’t give you them, instead make a new file by clicking File → New design File:
Liz_Thaler
omg thank you. that’s so silly. I was updating multiple browsers and everything and this was the actual issue.
  • August 22, 2024
I used the web app and this worked for me!
Shan_O_Brien
None of these have brought back my right hand side panel. 😕
Ayush_Soni
  • December 30, 2024
This worked for me! (was on mac desktop app)
Milad001
  • January 18, 2025
In the browser, remove the last part of the page’s URL and press Enter. Figma will recreate that part of the hyperlink when the page reloads, which should resolve the issue. (Simply reloading the page won’t work because the same URL persists.)
