PDF export - text not selectable
Show first post
titanas
  • 30 replies
  • April 2, 2024
@Antonio_Marquez glad to hear it works and your Figma workflow is now improved.
What specific features does the Super PDF plugin offer for merging frames into a single PDF file in comparison to using the Preview app workaround?
titanas
  • 30 replies
  • May 31, 2024
Hey @samanthasen776, there are two key benefits which are important to me. One is that I do what I do inside Figma, avoiding context switching especially when I’m on my laptop with limited screen real estate. The second benefit is that I can do this on both Figma and FigJam.
Amgad_Okail
syahra
  • June 29, 2024
I had a similar issue and no plugin can maintain the layout that I want. But finally, after trying this and that, I can export the PDF in Figma with selectable text! Here’s what I did:
  • Remove all opacity variables for layers or color, and make sure everything is 100%
  • Remove all auto-layout and groups
  • I used a Google Fonts typeface, which was not quite popular, but the PDF result didn’t work. So I tried to use a more common font first (Times New Roman) then tried to export and see the result (selectable or not). Once it’s selectable I could adjust it to my desired typeface.
It works now!
Marios
  • October 28, 2024
I found a solution! Export the screen as .pdf and then use Make PDF searcheable. Online OCR tool. to convert it to searchable and selectable text
BEN_GEORGE1
  • December 17, 2024
This worked for me thanks
daniell
  • February 12, 2025
Thanks for the heads up, Marios. This other OCR tool works the best IMO. The “I love pdf” one worked but ended up rasterizing my text which rendered it blurry at larger sizes.
Ryan Vickerman
We just signed an enterprise contract….wish I had known that this is an issue. It’s a deal breaker for us, as we need this for our legal/compliance team to review.
The only work-around that I’ve found is using the OCR feature in Acrobat. Not ideal and leads to junk text.
PDF export is table stakes for modern document software….what gives?!
GunnarW
  • March 20, 2025
This worked for me:
  1. To enable selecting text: Make sure the opacity of the text is 100% (use shades of gray instead of semi-transparent text)
  2. To make the copied text not have spaces between every letter: Make sure letter spacing is set to 0 (This kind of sucks, but at least it works)
