Context: I’m using Slide Deck mode:
Prior to the new update with 30 new features, I had been using Smart Animate to animate objects across multiple slides, with good results. Now the workflow gets more granular, and actually allows us to animate the objects within a single slide
MY PROBLEM: Now there is a limit of 1 single animation per object (e.g. FADE IN). I cannot apply a 2nd animation to the same object (e.g. FADE OUT), so I cannot have that object leave the slide. This means that an object that is brought into a slide via an animation cannot be animated out of the slide. It must remain, apparently.
Am I missing something really simple? Or is this a weird limitation on the animation workflow? All I want is for an object to appear and then disappear on the slide seamlessly.
New "Object Animations": How to have a single object move in, and then move out? (2 animations, 1 object)
