Alina_Trussova
Nested component, instance swap and stroke scaling issue
Icon stroke width behaves as expected inside the button (it scales with the canvas). However, as soon as it’s turned into a component and the icon is swapped, the stroke resets to a default value of 2px. The frame size behaves as expected.
Icon is resized using scale tool.
Problem appears both ways:
– creating button from scratch (works), make is a component (does not work).
– creating button component with same anatomy from scratch (does not work). Detach the same component (works).
Creating different sizes with variants for each icon is not an option due to the extensive icon library.
Is this a bug, or what could be causing this issue?
tank666
tank666Solution
September 8, 2023
Most likely you need to override the icon stroke weight in each button variant.
tank666
September 8, 2023
Alina_Trussova
Thanks!
– Icons are constructed properly (flatten, only one vector stroke layer and the same layer names, same properties)
– Also I did try creating a component responsible for size (3 sizes). It exhibits the same behaviour. When used in a button component stroke resizes back to original 2px.
Seems like a component adds additional parameters to the setup, but I can not figure out what and do I even have control over it. Currently it’s seems like a bug to me.
Does anybody have any ideas?
tank666
tank666Solution
September 8, 2023
Alina_Trussova
I see! That’s what I was missing! Highly appreciate your help.
Jay_Flaxman
Surely this is still a bug though? I have the same issue where I’ve created a component in which I’ve added an instance swap property for a nested component that I’ve scaled up. As soon as I try swapping the instance of the nested component, the stroke thickness reverts back to the original. If the original instance is scaled, why would the scale not apply to the swapped instance?
Lucas_del_Rio
November 16, 2023
This is a bug clearly. Been struggling these paste days with the same issue. Makes no sense honestly.
Alina_Trussova
Hi! I have been testing and noticed that I do not experience this problem anymore even without workaround.
So it looks like the bug is fixed now and maybe latest Figma update will help?
Mads_Hensel_dk
March 15, 2024
Ran into this problem/bug again today, so I don’t think it’s been fixed yet!
Amy_Martens
March 15, 2024
This definitely still happens and causes a lot of pain trying to use stroke based icon libraries with a design system built in Figma
March 26, 2024
Still same issue, If ikon or illustration with stokes in nested level inside a parent component. Stroke will not scale if instance is scaled small or bigger.
