Monitoring memory usage on a file after fixing performance issues
  • April 14, 2025
  • 37 views
Maz Tejani
Memory usage was very high on a Figma design file. Fixed it by removing hidden layers.
How do I show the improvement in memory usage before and after the fix has been applied?
Best answer by djv
Hi ​@Maz Tejani, thanks for reaching out!
Glad to hear you were able to fix your memory usage by removing hidden layers
You can see your Memory usage from the Main Menu > View > Memory Usage, but there isn’t an easy way to show before and after the fix. Your best bet would be restoring a previous version of your file before the fix to check the previous Memory usage. Then, you can remove the hidden layers again to see the updated Memory usage.
  • April 15, 2025
