Masks and objects not cropping correctly on art board when in prototype mode
  • March 18, 2025
  • 55 views
James_Garnham
There is a major mask cropping / scrolling problem - it affects every frame with an object that goes outside the bounds on the frame. It breaks every prototype. It cannot be fixed with a mask or with anything. Please see this video:
The red area should not be visible as it is outside of the art board bounds and yet when wanting to scroll a prototype page vertically it breaks because it does not crop the content correctly. There should be no way to see the red element when in prototype mode - this is a bug and needs fixing.
If someone thinks this is intended behaviour, they are wrong because most designers will want to have objects that run off the canvas or that are clipped. The main issue is that you would expect to use a mask to achieve this crop without additional scroll but Figma calculates the object measurements from the image within the mask not by the mask bounds, so therefore we all have a major problem with clipping, prototype and masking.
  • 4943 replies
  • March 26, 2025
Hey ​@James_Garnham, thanks for flagging this and apologies for the delayed reply!
I created a test file and objects outside of the bounds a frame are remaining clipped on a prototype with vertical scroll behavior as expected on my end.
It’s hard to see what your current settings are from your screen recording, because we cannot see the Layers panel or Design/Prototype panel.
Can you please confirm if you’ve checked Clip content in the Layout section of the Design panel for your chosen frame?
