Jul 29, 2024 9:51 AM UTC
Issues with component overrides not updating in figma
What to do if there’s an issue with component overrides in Figma where updates to the master component do not automatically reflect in all instances. The master component was edited and saved, and while some instances updated correctly, others did not. Have you go through this situation? If so, what did you do? Any advice please…TIA
Gayani_S
Jul 30, 2024 12:13 PM UTC
Hey @Louis_Otto, thank you for reaching out!
I’m sorry to hear that you’re having trouble use your components. Can you please kindly share a screen recording of this issue occurring on your end? Please include the entire screen in your recording so that we may view your workflow.
In the file where this issue is occurring, can you try the following steps:
  1. Select all layers
  2. Launch quick commands (cmd /)
  3. Search for and apply the option “Repair component connections”
  4. Once complete refresh the page, then try publishing a new change and check if the update shows in the file.
Note that this command can only be applied one page at a time. If this resolves the issue, repeat steps 1-3 on all pages in the file containing instances of this component. Let me know if this works for you! If not, I’d love to share this with our technical team so that they may take a closer look.
Gayani
