Guilherme_Xot_Pironi
March 28, 2024
Is it possible to create an adaptive res bottom navbar in a prototype?
  • March 28, 2024
  • 395 views
I’m creating a mobile prototype with adaptive resolution containing a fixed navbar at the bottom of the screen and a fixed header at the top of the screen.
I was able to make the header stick to the top of the prototype as the user scrolls the content underneath it. However, I can’t do the same with the navbar at the bottom of the screen because there is no option to fix an element’s position at the bottom of the screen.
This means that the navbar scrolls with the rest of the screen if I don’t fix its position. However, if I do fix it, it stops adapting to the screen size of the mobile phone of the person testing the prototype.
Is there a way to solve this?
Best answer by tank666
Do the same as with the header (position: fixed), just set the bottom constraint for the bottom navbar.
Figma Learn - Help Center
March 28, 2024
figma duvida
Reference image
tank666
tank666Solution
March 28, 2024
March 28, 2024
Thanks! It worked! I was using an auto-layout on the main frame so I couldn’t set the constraints. I removed the auto-layout and it worked like a charm
