Interactive nested component not working...again!
Marlon_B
Not sure if I’m going crazy or missing something completely basic but I have a component which contains several nested component instances for . The expandable nav is simple enough with 2 states of OPEN and CLOSED and I have several of these inside a auto-layout frame, which allows each nav to be expanded or collapsed.
The interaction works fine until I convert the into a component, then the nested interactions no longer work!
Here is an example file containing an instance of the component which do NOT work and a detached instance which works perfectly!
Figma – 8 Oct 24
Any ideas welcomed!
Sanjoy_Chakraborty
I am also having the issue
Aaron_H
  • January 24, 2025
I’ve hit this problem today. I have buttons with interactions in the expanded state of a drop down menu that refuse to work in the prototype. If I manually set the menu state to expanded in the prototype they function correctly.
