Interactive Component - Can't prototype to another screen
Ray_Williams
When creating interactive components e.g a button, it seems like I can’t use it to prototype from one screen to another, is that a bug or something that Figma can’t do?
e.g so I created a screen with the interactive component button when I click prototype to another screen it won’t work. Has anyone else experienced this problem or is this something Figma can’t do?
Edward_Battistini
you should provide a playground file if you need help, as it is hard to understand the problem you are having…
Ray_Williams
Hi Edwards,
Thanks for your quick response, so in screen A I have an interactive component when I hover the button the color changes but if I click on that button to load another screen e.g B it wont work, you can do this in other tools like XD, not sure if I am doing something wrong or Figma can’t do that just show the pretty hover component but not use them to prototype from screens to screens
Edward_Battistini
As a wild guess you might have the interaction in the wrong place.
First Make sure you apply the right behaviour to the button.
Second Apply the navigation behaviour in the context of your frame
Hope this helps,
ImageTech_Solutions
Hello Edward Thank You so much I was looking that
Robin_Pettersson
I have exact this setup and sometimes it works, sometimes it doesn’t
Especially when the second screen is a altered copy of the first screen
Robin_Pettersson
One mistake that I’ve sometimes made is that I accidentally have copied the frame having a duplicate with the same xy positions. When drawing the connections Figma connects with the underlying and all changes is on the overlying.
