Instant Swap Property - New UI
Daraa_Design_Team
Hi,
If there’s any chance you can please take a look at the UI for the instance swap property setup in the new UI. It’s really, really challenging to find. Took 1.5 days to realize you have to set the property to the component then select the frame to swap then go back to the top and hit the 3 dots. I know I’m still learning but at least with the boolean right click old UI there were tons of videos of people showing that. Here every single old video for IS is based on old UI. 😦
Have the same problem. It took forever to understand the new flow.
Rubem_Pechansky
Wow, thank you! I suppose it’ll take 1.5 days for me too if I haven’t found your post 😃 I really hope the guys at Figma re-create the old icon. [Removed a mistake here]
Kelly.Viljoen
I still don’t understand 😦 I can’t find the 3 dots you mentioned. I managed to set the property up, but from there I am lost.
Daraa_Design_Team
Ok so you go to main component. Go to the plus sign on top right. Add the swap property. Then go to the property/element/thingy you wanna swap. Select. Go back to top right hit 3 dots menu button you should be able to assign the property now. Hope that helps
