In my plugin I am unable to set the image in frame
Rohit_Rajan
This is the code I am using to convert the image URL
  const imageData = await fetch(data.coverURL);
    const imageArrayBuffer = await imageData.arrayBuffer();
    const imageUint8Array = new Uint8Array(imageArrayBuffer);
    // Create a new image in the Figma document
    const imageHash = figma.createImage(imageUint8Array).hash;
    console.log('Image hash:', imageHash);
and here is the URL
https://is1-ssl.mzstatic.com/image/thumb/Publication6/v4/60/29/a3/6029a31a-bf59-43fb-3a29-23ff12d8631d/Cover_BellsBigMove.jpg/800x800bb.jpg
Getting this error
VM4198:6 Refused to connect to 'https://cors-anywhere.herokuapp.com/https://is1-ssl.mzstatic.com/image/thum…/6d6c0fd5-0d8b-df53-5a2c-1d349e0ed9b3/617513652833_cover.jpg/500x500bb.jpg' because it violates the following Content Security Policy directive: "default-src data: blob:". Note that 'connect-src' was not explicitly set, so 'default-src' is used as a fallback.
Best answer by Gayani_S
Hey @Rohit_Rajan, I’ve got the following response from the team:
You need to add any domains you’re planning to fetch from to the networkAccess.allowedDomains field in your manifest.json file.
“networkAccess”: { “allowedDomains”: [ “https://is1-ssl.mzstatic.com”, “https://cors-anywhere.herokuapp.com” ] }
Have you tried using the createImageAsync API method? createImageAsync | Plugin API
Let me know if this helps!
Gayani_S
  • 2145 replies
  • July 2, 2024
Hey @Rohit_Rajan, thank you for reaching out!
I’ve reached out internally to the teams for help, I’ll come back to you once I have more information.
Appreciate your patience in the meantime!
Gayani_S
  • 2145 replies
  • July 2, 2024
