I am working on a Figma prototype where selecting an option from a dropdown menu (options 2, 4, 6, 8) not only updates the menu’s display but also changes another component on the same screen. Specifically, I want the selection to dynamically adjust the number of squares displayed in another component. How can I achieve this interconnected behavior within a single screen without creating separate outcome screens for each dropdown option?
How to Link a Dropdown Menu to Another Component in Figma? Quest
Best answer by Vishal_Ramawat
So the component has 3 Variants with Property1 set to 2/4/8
And then on instance you link the DD variable to it’s property
You can create an ‘Empty’ Variant in Squares component with Property 1 as “Select”, so when DD value is Select, you can show an empty container.
