tank666
November 21, 2023
The endpoint you reference returns all components in the file.
July 10, 2024
@tank666 are you sure?
I have the same issue than @Bryan_Wong .
From what I tested:
  1. /v1/files/xxx/ returns the whole tree, entire local components, but remote components are just listed with a “key” (no fileId or so)
  2. /v1/files/xxx/nodes?ids=$NODE_ID won’t bring much information about the fileId
  3. /v1/files/xxx/components returns only published components
  4. The only way to get information about the remotely used component is by using /v1/components/$KEY_ID but it requires doing 1 call for each component
