How to get the applied color variable in a Figma plugin?
  • February 20, 2025
  • 5 replies
  • 166 views
Franco Tirabasso
Hi everyone,
I’m developing a Figma plugin that extracts design properties from selected nodes, including text styles and color tokens.
For text styles, I successfully retrieve the applied style using:
const textStyle = figma.getStyleById(node.textStyleId);
This works great for identifying and mapping text styles.
However, I can’t find a way to get the color variable applied to a node. When inspecting node.fills, I only see the RGB color, but not the token assigned in Figma variables.
Example:
In Figma, the text color is set using a variable:
color: var(--color-foreground-primary, #000);
But when I check node.fills in the plugin API, I only get:
  type: "SOLID",
  color: { r: 0, g: 0, b: 0 }
I tried checking node.boundVariables, but it doesn’t seem to return color-related variables.
Questions:
1️⃣ Is there any way to get the applied color variable name (e.g., "color-foreground-primary") in a Figma plugin?
2️⃣ Can we extract this information from boundVariables, fills, or another API method?
If there’s a workaround, I’d love to hear it! 🚀 Thanks in advance.
Best answer by tank666
You can get the variables bound to the fill in the following ways:
node.boundVariables;
node.fills[i].boundVariables;
node.fills[i].gradientStops[i].boundVariables;
PaintStyle.boundVariables;
PaintStyle.paints[i].boundVariables;
PaintStyle.paints[i].gradientStops[i].boundVariables;
To get the variable name, first get the variable ID using the above properties and then use the getVariableByIdAsync(id) method.
tank666
  • February 21, 2025
Franco Tirabasso
That worked perfectly! Thanks
Heath_Flohre
I was also successful pulling the fill variable id and name using node.fills[i].boundVariables.color.id; but I’m not able to pull a text variable id and name from a text layer using the same script. node.boundVariables.fontFamily.id returns undefined and node.boundVariables.fontFamily returns the array. What am I missing?
tank666
You need to check the array element.
node.boundVariables.fontFamily[i].id
The same applies to the fontStyle property.
Heath_Flohre
I was using array [1] when it should have been airy [0]. node.boundVariables.lineHeight[0].id worked! Thanks for the help.
