Dianne_Banawon
Jun 26, 2024 3:06 PM UTC
How do I present a component set?
hi, beginner Figma user here. I’m having trouble with presenting my prototype. I have three frames in 1 component set. when i click present, it says ‘a prototype needs at least 1 frame’ when i add a frame, and present it, the frame inside the component don’t show up. instead the frame that i added shows up and covers the entire thing. and when i put the frame behind the component (its size is just enough to fit the 1st frame in the component), it shows up but i can’t skip to the next frame in the component. also when i put the 1st frame from the component in the frame that i added, i can’t use the “Change to” interaction anymore (which was the reason i turned it into a component set.)
please help thank you
DameGeri
DameGeriSolution
Jun 26, 2024 3:18 PM UTC
Hi Dianne, hoping I’ve understood you. I would create a frame, i.e., a page as if you were creating a web page to layout your designs - these are also frames. Once the page is created, navigate to your Assets tab and add your component to the newly created page. When you preview your page, your component should hopefully display correctly and any interactions between the three should work.
So basically roll back removing those additional frames you created in your components set - add the interactions, then add component to a page from your assets panel.
I hope this helps.
DameGeri
DameGeriSolution
I hope this helps.
Dianne_Banawon
Jun 26, 2024 4:42 PM UTC
thank you so much!!
