How can i use localStorage in a plugin?
Hello,
I’m developing a plugin based on VueJS 3. I scratched from this project GitHub - joaomarcelofm/figma-plugin-template-vue: A lightweight template for Figma plugins using Vue.js .
I have this code at main.js:
axios.interceptors.request.use((config) => {
    const accessToken = localStorage.getItem('accessToken')
    if (accessToken)
        config.headers.common['Authorization'] = `Token ${accessToken}`
    return config
}, (error) => {
    return Promise.reject(error)
How can I save my accessToken? I can't use [figma.clientStorage](https://www.figma.com/plugin-docs/api/figma-clientStorage/) 'cause it is undefined at `main.js` I can't use `parent.localStorage` or `localStorage` 'cause it is prohibited
Best regards
tank666
tank666Solution
August 27, 2023
There is nothing complicated here. Just send a message from the UI and receive it in code.ts.
figma.com
tank666
August 27, 2023
The localeStorage is not available for plugins, so use figma.clientStorage.
Alex52Author
August 27, 2023
I understood that I couldn’t use localStorage. Do you have a code example that uses Figma’s storage in a Vue/React app?
Best regards
tank666
tank666Solution
August 27, 2023
figma.com
Alex52Author
September 3, 2023
Many thanks for your reply. I made same solution:
code.ts
figma.showUI(__html__, {width: 500, height: 650});
figma.ui.onmessage = async (msg) => {
  if (msg.type === "set-value") {
    await figma.clientStorage.setAsync(msg.name, msg.value);
  else if (msg.type === "get-value") {
    const value = await figma.clientStorage.getAsync(msg.name);
    figma.ui.postMessage({type: 'return-value', value: value});
storage-wrapper.js
export function setFigmaStorageValue(name, value) {
    window.parent.postMessage({pluginMessage: { type: "set-value", name: name, value: value }}, "*");
export function getFigmaStorageValue(name) {
    window.parent.postMessage({pluginMessage: { type: "get-value", name: name }}, "*");
    const promise = new Promise(function(resolve, reject) {
        window.addEventListener(
            'message',
            function(event) {
                resolve(event.data.pluginMessage.value);
            {once: true}
    return promise;
view.js
logout() {
      setFigmaStorageValue('access-token', null);
