Same issue here. Not sure what needs to be done. The hot reload plugin option doesn’t get checked as per the documentation
I have the same issue. Figma is only watching if the manifest.json file changed. So if you want to hotreload the plugin just change the manifest file or make sure the file gets updated somehow every time your build tiggers so the changed date and time of the file is new and Figma will reload the plugin.
This makes sense and sad at the same time. 🥲
It gets checked but only when you access the menu via rightclick somewhere and then you can select hotreload.
Ok, but this isn’t productive.
Is there any alternative?
Does anyone have a solution for this ?
I faced the same issue but it was from Webpack, not React.
Adding cache: false
to HtmlWebpackPlugin
fixed the issue of my dev environment.
This not working for me.
My files ui.js and main.js are updating, but the Figma not listening.
If you are working with stylesheets, you might find my new package useful
GitHub
I was having the same issue. It seems like launching the plugin from Resources > Plugin
works better than from the right panel relaunch
button.
Did you find a solution for this?
Hi, I don’t mean to highjack this thread but I’m the author of a library that makes developing Figma plugins easier. One of the main features is it uses a local development server instead of re-building the file with each file change. I think this will solve your issue as it doesn’t rely on Figma to reload the plugin. One caveat is that when you publish your plugin, you must create a build before doing so. But it’s a small price to pay for a better developer experience.
You can check it out at plugma.dev.
Let me know if you have any feedback.
Cool shit! This really solved my urgent problem. I spent most of the day just implementing “building Figma plugins with vitejs” and then encountered the hot reload issue. Just when I was about to give up, I saw your post. Plugma really perfectly solved my problem.
This is great to hear. I’m so glad it helped you.
