Laura75
Dec 31, 2024 5:54 PM UTC
Figma run out of memory after trying to export in SVG format
Please search for existing topics before posting! Press 🔍 at the upper right to search.I am working on a project and it is divided into several frames. My problem is that when I try to export it as SVG, Figma responds with:
“This file has run out of browser memory. Your work isn’t lost, but you won’t be able to use this file unless memory usage is reduced.
In recovery mode, you can access tools and tips to reduce memory usage and continue using the file safely”.
After this, I have looked at how much % of memory I am using and I get that I only use 8%, unlike other posts that have a similar error where the % reaches 65% or more.
As a result of some testing, if I try to export it as a different file (JPG, PNG or PDF) it gives no problem. Only when I try to export it as SVG.
As a last detail, I am using Chrome, on MAC.
Best regards and thank you very much in advance.
Georgia_Rust
Jan 27, 2025 11:13 PM UTC
Hi ​@Laura75 👋 we are investigating reports related to this.
Can you submit a report with the link below so we can investigate this issue? Sharing the file with our support team would be really helpful. https://figma.bot/submitreport
