Kochar_Neha_Designer_UX_Design
Jun 15, 2023 3:19 PM UTC
Figma connectors not snapping to objects
Figma connectors are no longer snapping to any objects, i;ve been using them all day and it’s been working fine and suddenly just stopped snapping to any object
Jul 7, 2023 7:34 PM UTC
This also just happened to me! Did you find a solution?
Aug 8, 2023 9:23 PM UTC
This also happened to me and it was very frustrating until I noticed a transparent object was on a layer above the item I was trying to connect to. Once I locked that/shifted it backwards, I was able to connect to the object I needed. I know this is a later response but I hope this helps someone!
Aug 8, 2023 9:25 PM UTC
Unforch no resolution, I was able to recover the functionality very randomly (just restarted a few times over a couple days)
Oct 9, 2023 9:10 AM UTC
Connecting lines are tied only to the center of the figure. This is very inconvenient. Please return the previous functionality.
Colleen_Moriarty
Dec 20, 2023 7:18 PM UTC
I’m experiencing the same issue. Connector lines won’t move where I want them to go, they randomly fly all over the place have no proper dragging functionality. I can’t snap them to anything that I want to snap to, they just go wherever.
Mar 13, 2024 5:16 PM UTC
I’m having this problem in a huge way and I can’t figure out what I’m doing wrong. It’s infuriating! Where are some good resources on how much you can do with layers? Is there a limit to how many you can have? I suspect my excessive layering is the problem with my inability to connect my objects in the huge flowchart file I’ve created for doing genealogy work.
Mar 14, 2024 8:22 PM UTC
Hey @Gulya_Arabova,
To place the end point of a line on any part of an object (and avoid the snapping the line to the side of the object), you can hold down ⌘ Command (Mac) or Ctrl (Windows) while moving the line.
Mar 14, 2024 8:25 PM UTC
Hey @Kristin_Ellington, sorry to hear you’re having trouble with connectors!
There isn’t necessarily a limit, but it’s hard to be sure what’s happening without seeing your file. Can you share it with our technical quality team here? https://help.figma.com/hc/en-us/requests/new
Please use your Figma account email, include a link to the file, and share it with support-share@figma.com, so they can take a closer look.
Shive_Cody
Oct 17, 2024 1:17 PM UTC
This is useless. You have an example in this post. Everyone is asking for the prior functionality to be returned – simply draw a box, draw another box, then add an arrow connecting the two boxes, then move one box somewhere else. The arrow should remain “glued” to both boxes. Simple as that. I’m going back to DrawIO, which works perfectly.
Folks, this is table stakes, especially if you’re trying to prototype in front of a live audience.
Gregory_Brock
Nov 6, 2024 11:29 PM UTC
I ended up clearing my cache and it fixed it! Try that, it’s in your troubleshooting options.
