Regi
February 29, 2024
Figma api: comments
Hi, does Figma in any way allow to interact with comments through it’s api? I.e. retrieve data?
tank666
tank666Solution
February 29, 2024
tank666
tank666Solution
February 29, 2024
Regi
RegiAuthor
February 29, 2024
thank you @tank666
Regi
RegiAuthor
March 4, 2024
Continuing this question - I am able to retrieve all comments for a file using REST api, I was however wondering if there is a way to only retrieve comments for a specific page? or perhaps filter comments using page ID somehow? As there might be a lot of comments 😕
tank666
March 4, 2024
Use comment.client_meta.node_id to get the node and, if required, its parent.
Regi
RegiAuthor
March 4, 2024
My goal is to be able to specify a page (name or ID) and extract the comments from the given page.
Considering your reply - how does one return the parent of the comment.client_meta.node_id? I could filter the comments based on that, but I seem to be stumbling on that part.
The only solution I’m currently finding is making a separate request which looks through the document->page->children and then having to manually match the output of that to comment.client_meta.node_id to see if it’s on I page I want to check for comments.
Maybe I’m missing a simple keyword or something here… Thanks again!
tank666
March 4, 2024
figma.getNodeById(comment.client_meta.node_id)
Or an asynchronous function (getNodeByIdAsync).
And if the node type is not page, check its parent.
node.parent
Regi
RegiAuthor
March 4, 2024
and I’m guessing there’s no REST api to do the same?
tank666
March 4, 2024
The REST API has endpoints such as GET file and GET file nodes. Use them to find the required IDs in the JSON response.
