External Javascript file for my plugin
Amr_Esam
I am trying to create a plugin with UI
the problem is ui.html file don’t want to load my ui.js tag
thanks for help
Best answer by Gleb
this is the answer
tank666
  • 4870 replies
  • September 3, 2022
Embed your JavaScript code in HTML.
Amr_Esam
  • 5 replies
  • September 3, 2022
and what about accessing external libraries? same problem
tank666
  • 4870 replies
  • September 3, 2022
How did you include the external library?
<script src="https://hostname.com/library.js"></script>? There shouldn’t be any problems with this.
Amr_Esam
  • 5 replies
  • September 3, 2022
like that
<script src="ui.js"></script>
tank666
  • 4870 replies
  • September 3, 2022
You have to embed js code in HTML:
<script>
    //your code
</script>
Amr_Esam
  • 5 replies
  • September 3, 2022
So i cannot put my UI code in seprate js file?
Amr_Esam
  • 5 replies
  • September 3, 2022
It don’t even want to load js files like that:
tank666
  • 4870 replies
  • September 3, 2022
figma.com
Sorry, but I can’t confirm this. For example, if I include the jQuery library, then I can access it in code.
<script src="https://code.jquery.com/jquery-3.6.1.min.js"></script>
<script>
    // Display the version number of the external library.
    console.log($.fn.jquery)
</script>
Amr_Esam
  • 5 replies
  • September 3, 2022
thank you 🙂
What is the difference between loading from CDN and local file? Why you can load via CDN but can’t the local js. What is the difference?
  • 4707 replies
  • March 19, 2023
Figma doesn’t load your whole computer onto their servers when you publish a plugin, it only loads the files that are listed in the manifest: code.js and ui.html. It doesn’t care/know about any other files that exist in your file system and how they can be related to your code.
If you need to use external libraries, you either need to bundle them into one file (using Webpack, ESbuild etc.) or use a CDN.
What is the way to use external library in ut.html via Webpack? If Webpack will create bundle in dist/code.js I can’t use it as . How can I use some node_modules that I want to access in ui.html with using of Webpack?
@Gleb any ideas on what @Yaroslav20 is asking here? I have the same request. Thanks!
  • 4707 replies
  • January 10, 2024
this is the answer
Indeed this (Webpack: see example) works great! Thanks!
