I created a component with a container that has the height set to “hug content,” with top and bottom padding. Inside the container, there’s an instance that should adjust the height, causing the parent component to resize based on the content.
The component works as expected, but when I use an instance of this component, the height becomes fixed and I can’t adjust it. The only way to make it work is by detaching the instance.
What am I doing wrong here? Is this the intended behavior, or should the height be adjustable without detaching the instance?
I created a screencast so it is easier to understand the issue
thanks in advance
