Changing variable mode not working
  • November 7, 2024
  • 4 replies
  • 173 views
Halid
I have set up dark and light modes in the variables.
in the light mode, the text has a fill: brand/default/text-brand with green color. dark mode is the same variable with different value - white.
when I apply dark variable mode to the button, the text fill does not change
even though the dropdown shows that if I select it, it should be white.
the variables are in a separate library file, where everything works as intended:
  • 2471 replies
  • November 8, 2024
Hi there,
I tested it with a simple frame on my end, and it seems to be working fine.
Could you provide a bit more detail about the issue you’re experiencing? A video recording would be really helpful.
Toku
Halid
  • 4 replies
  • November 8, 2024
Hey there, thanks for the reply.
Here are the recordings. Basically, the design file has a library added, and the library has everything set up properly, but the mode does not change the text color, even though in the dropdown it clearly shows that it should be a different one. after selecting it, it changes to proper color.
Halid
  • 4 replies
  • November 8, 2024
Here is one more video
  • 2471 replies
  • November 13, 2024
Hi there,
Thank you for your patience! It seems unexpected, so I’ve connected you with our support team via email. Someone from the team will reach out to you shortly.
In the meantime, if you have any file links, please share the URLs with access granted to support-share@figma.com. Don’t worry, this won’t affect your billing!
Thanks for your patience.
Toku
