Ganesh
Jan 15, 2024 12:54 PM UTC
"Change To" is not enabled for me to select while try to prototype
“Change To” is not enabled for me to select while try to prototype. Hence self unable to prototype my calendar month
Can you please help me to fix this issue
Jan 16, 2024 3:40 AM UTC
Hi Ganesh,
Thank you for reaching out and sharing your screenshot! I’m not entirely certain, but it appears that you are trying to apply the “Change to” action between two distinct components.
The “Change to” action is for variants within a component set. Unfortunately, it cannot be used between two separate components or top-level frames.
You can only create interactive components using variants from the same component set. And, interactive components introduce a prototype action called “Change to.”
For more details, you can refer to Create interactive components
Hope this clarifies things!
ARTHUR_ULRICH_EWANE
Nov 15, 2024 1:47 PM UTC
Choose the option create component set
