Ivan24
Nov 4, 2023 5:16 PM UTC
Change prototype flow based on starting point
Hi all,
I have a screen that has 2 options: Option A and Option B
In prototype, once I select one of these 2, I go throught some pages which are the same in both Options A & B. Then I come across another selection. In this screen I have Option C and Option D
Now the next page shows content based if user selected Option C or D. After that, once user finishes that flow, they are presentated with another page based on Option A or B.
My question:
How can I change the prototype flow based on the “selected option” in the background? Is there a token I can create and based on that token value the flow (arrows) go in different directions? Is this possible?
Thanks in advance!
Ivan24
Ivan24Solution
Nov 6, 2023 2:24 PM UTC
I figured it out. Had to use Boolean and Condition logic!
tank666
Nov 4, 2023 5:23 PM UTC
I’m not sure I understood your problem well, but take a look at this thread: Prototype flow sharing screens in both A & B flow.
Ivan24
Ivan24Author
Nov 6, 2023 2:04 PM UTC
Hi @tank666 , thanks for the answer. But this is what I mean:
To simplify it - Based on user’s choice on Screen 1.0., the prototype opens a different screen when they tap “Next”
Another example would be: If I hit on a Cart icon, if there are no items - Empty page. If there are Items, then page with those items.
So conditional logic but for prototype
Ivan24
Ivan24AuthorSolution
May 20, 2024 1:23 PM UTC
Hi there, can you explain the steps you took to with boolean and conditional logic to make this work?
Polly
Sep 2, 2024 1:11 PM UTC
Hi Ivan24,
We are facing the same problem. I’m curious how you solved it, was it once you selected a option in Screen 1.0. and used boolean to pass the values ​​to 2.0. and 3.0. 🧐
Thank you.
