Federico_Fala
Apr 30, 2024 5:56 PM UTC
[BUG] Interactions duplicating in a conditional interaction when drag and drop
In my opinion a BUG.
While there’s two conditional interactions with a “set variable” with the same variable and value pair, when drag and dropping an additional interaction for reorganising sequence of events, things gets duplicated.
In my specific example I have two conditional interactions with the same set variable [Red] to “dark” inside. If I had another interaction inside either conditional interactions and reorganise the order, interactions starts to get duplicate in the other conditional element.
See video:
May 2, 2024 12:42 AM UTC
Hi there,
Thanks for reaching out. It looks strange! I’m checking with our internal team. I will get back to you when I have anything I can share with you.
Thanks for your patience.
Toku
Federico_Fala
May 2, 2024 9:20 AM UTC
Actually, I’ve found another simpler way to trigger this “bug”:
  1. Create a trigger of any kind for an object on canvas
  2. Add as many conditional (empty) as you want
  3. Add a “set variable” outside of the conditional
  4. Drag and Drop the “set variable” inside either conditional → “set variable” is duplicated.
May 10, 2024 3:56 AM UTC
Thanks for the details! I’ve shared this with our product team, and they’re now aware of this issue. I’ll get back to you if there is anything I can share! - Toku
Tamara_Did_Design
Aug 22, 2024 12:14 AM UTC
I know this is a bug, but I think you just saved me a lot of headache by recreating a bunch of logic 😅
I kind of hope one day there will be a way to duplicate set variable statements!
