Jakub_Vlk
Apr 29, 2021 2:32 PM UTC
Adding images with original names
How to place image to Figma without any suffix - i need to have original unchanged names of them and figma adds 1 on end. Thanks 🙂
Power Member
Apr 30, 2021 12:08 AM UTC
I haven’t tested but this setting might help. If it doesn’t there is no other way. You can only batch rename all layers and remove the numbers by matching them with regex.
Figma search menu: Rename duplicated layers setting
Ricardo_Pitanga2
Feb 5, 2024 11:36 PM UTC
Disabling “Rename duplicated layers” had no effect on the name of imported images. They still receives “1” as suffix. The real issue is when I have a series of numbered images, in which case it crates confusion by adding another number at the end, becoming something like “file-name 1 1.jpg”, “file-name 2 1.jpg” etc.
Power Member
Feb 6, 2024 6:54 AM UTC
you can batch rename them (cmd + R) to remove the extra numbers
daken
Sep 7, 2024 8:03 AM UTC
By placing multiple images into Figma, this problem can be prevented.
