Adding content into an expansion panel
Hi all,
I’m having trouble adding content into an expansion panel (specifically a table w/ columns and rows). Any tips and tricks I can try?
Josh
  • Former Community Manager
  • 1019 replies
  • February 4, 2024
Hey @Humberto_Gutierrez do you mind sharing a bit more about what you’re looking to do. Not quite sure what you mean by expansion panel. If possible if you could share any screenshots or recordings, we can then point you in the right direction from there. Thanks! 🙂
I’m trying to get them to interact without the overlay.
  • 2544 replies
  • February 5, 2024
Hi @Humberto_Gutierrez
Thanks for the screenshot.
It seems like your prototype includes nested instances, but is that correct? If I understand correctly, this could be a feature limitation where changing variants or swapping instances in nested instances doesn’t update their sizes according to the new selections. But there’s a workaround for this.
You can enable auto layout on each variant of your components, which should allow the nested instances to resize correctly. If you’re okay with sharing the file link, I may be able to take a closer look and help you implement this workaround if needed.
I hope it helps!
Toku
Yes, I’d like for them to be nested under each other with some being indented after each other.
https://www.figma.com/file/7kKjBejo6yCjstqnjOcvHU/Untitled?type=design&node-id=2%3A3458&mode=design&t=rMOf3GxkQTVG1HNd-1
  • 2544 replies
  • February 5, 2024
@Humberto_Gutierrez thanks for the link! Could you give us the view permission for the file? Probably anyone with the link can view would be fine, if you’re fine!
Toku
ahhhh. unfortunately I’m unable to… looks like its blocked via my admin. using my work account to build. 😕
yeah, I’m able to get the panels to expand but they keep overlapping each other instead of moving the other panels below the expansion. 😦
  • 2544 replies
  • February 6, 2024
@Humberto_Gutierrez thanks for checking!
Then, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new. They can give you further support!
Done! Thank you for the help!
