Adding a shadow to a frame via a plugin
  • February 12, 2024
  • 365 views
Jonah_Goldsaito
Based on the plugin Effect API page, I would assume this is the right format for assigning an drop shadow to a node:
newFrame.effects = [{
type: “DROP_SHADOW”,
color: {r: 0, g: 0, b: 0, a: 1},
offset: { x: 0, y: 4},
radius: 4,
Unfortunately it fails silently. Anyone know how to do this properly?
Also, for any Figma team members out there, would be great to:
  • Get an error that highlights the malformed property causing this to fail
  • Have an example on the API page
Best answer by tank666
Add all required properties (including blendMode, visible).
figma.com
You should see errors in the console.
tank666
  • February 12, 2024
figma.com
Jonah_Goldsaito
Hey @tank666, thanks!
I didn’t notice the ? syntax on the variable names. That fixed it! 🙌
Notes to the Figma team:
  • Why are properties like visible and blendMode not given very obvious defaults of true and NORMAL respectively? The blendMode description even says, "The typical default value is “NORMAL”.
  • Showing an error for what’s missing would be amazing!
  • Stating required in plain text in the description would be way harder to miss.
Jonah_Goldsaito
Oops. Was missing the error amongst other noise.
