Stop all tabs to closing when restarting Figma?
Sebastian_Hall
Hi there,
At this point it feels like I’ve searched everywhere. After the latest update, Figma has started to close all my tabs when I restart or shut down the desktop client. I tend to use the tabs for different files so I can quickly can jump between them when discussing with team or just to copy specific bits across. Now I end up having to re-open all my files every time I start Figma which is suuuper annoying and time consuming.
Is there a way to stop this from happening and tell Figma to simply load with the tabs open like it used to?
Best answer by poiru
Hey! The latest Windows build should fix this: https://desktop.figma.com/win/build/Figma-98.14.0.exe
Sorry about the trouble!
Jason_Ming_Hong
I’m having the same issue.
poiru
  • Figmate
  • 21 replies
  • May 27, 2021
Sebastian_Hall
Yes when I started it up this morning all my tabs was back! seems to be ok, thank you! 😃
Alex10
  • 4 replies
  • June 7, 2021
I’m using Figma beta 98.14 and the issue is still there, at least from time to time
Aishat_Mosuro
I use a mac, and this issue still exists
Oleg_Sulyma
The issue still remains on MAC. Its very annoying.
Sara_Ferreira
Mac version is still not solved
Sai_Priya
  • January 11, 2022
@figmadesign do something about this for mac users!
Rodrigo_Muller
@Figma_Support is there a solution for this for Mac yet?? It is very annoying that it keeps closing all tabs after I update or restart the application.
Ivan_Bykov
Found a temporary solution for mac owners. If you close figma using the cmd+q hotkeys, then all tabs are saved. If you close the application in a different way, then the tabs are closed.
Mahinur_Khan
I use a Mac, and this issue is still there, how can we solve? Please update…
Hesam_Mousavizadeh
Thanks man!
Robert_Franckowiak
26/08/2022
After last update this issue come back. The only way to prevent closing tabs is ctrl+q (windows)
Omar_Chelbat
I too am experiencing this same issue.
Niklas_Susanne
The 98.14.0 is not longer able to work since updates are requested. However I still do have this issue with the latest version, that all tabs close when shutting down. This really makes it very hard to work across teams.
Niklas_Susanne
Using PC version with the latest update (116.3.7) but still not working. This is really annoying and hindering so much :-/
Cant there just be an option to switch on/off like you can do in all Browsers and PDF readers?
Niklas_Susanne
you made my day! 🙂
Sebastian_Hall
Updated to version 116.3.7 on my PC and this issue have now come back 😦
Arto_Seppanen
yep, tabs gone after shutdown (pc, 27.9.2022)
Daniel_Nauck
Yes, same here. … 😦
