Solved: Is there a way to increase font size in FigJam?
Javi1
All I’m seeing is the options for Normal, Heading, Subheading and Title. For a really big board / activity, is there any way to increase the font size?
Best answer by Josh
You can now select a custom font size within FigJam. Hope this helps!
Thomas_DiNatale
You can copy and paste text from Figma design files to get larger sizes. It displays as custom in the FigJam type size selectors. It’s a hack but works when you need readable copy at zoomed out scales
Christopher_Chris_Cappella
I think the hack mention is the only option beyond the 4 type sizes provided.
My two biggest complaints about Figjam are this (limited font size control) and no ability to adjust line weight beyond thin/thick. Color isn’t as a big a deal, but that’s limited too.
Jo13
  • October 19, 2021
Hope this gets sorted soon. Its a bit of a deal breaker for me.
Jussef
  • October 30, 2021
+1 for this improvement
careapp
  • November 10, 2021
I too would love to see user configurable text sizes (or let an admin define them in a shared style library)
Adam22
  • November 23, 2021
This is really needed, up voting, it makes Figjam really unusable.
gokhan
  • November 27, 2021
I assume all of us need such a natural need as per text.
Melissa_Myers
I cannot use FigJam bc of this. I will use Mural every time bc the text sizes don’t need adjusting every single time I type anything. The default font size is much too small. I want a way to change defaults.
Rebecca5
  • 5 replies
  • January 5, 2022
Just bumping this as a great idea :^)
Stephenson_Laura
+1 for this, really want this improvement!
Monique2
  • 9 replies
  • January 23, 2022
+1. The largest and smallest font can’t be read together at the same time, the variation in size is too big. It’s the only thing that stops me from using fig jam
Robert_D_Aveta
+1 to everything everyone else has already said.
Mo_Nimbus
  • March 10, 2022
Bumped. Would be nice if font size was just a number you can change like in most other applications
Scott_Ollivier
This is bizarre. I keep thinking there is something wrong with my browser or laptop. How can this still be a problem? Really does limit the use of FigJam to just super crude collaboration, but that doesn’t give with some of the FigJam templates I see out there, whose text actually comes in as “Custom.” Huge UX miss here.
Josh
  • Former Community Manager
  • 1019 replies
  • April 7, 2022
voxelwren
This menu does not show up for me reliably. Using the Figma concept map template, none of the bubbles can adjust text size. If I paste text it comes with the original formatting. If I Shift + cmd + V paste text it takes the bubble formatting but is too small to read. No menu like this appears for the text box and all of the options under text > adjust are greyed out.
If I add a custom text box it doesn’t stick to or affect the size of the bubble.
Amanda15
  • August 2, 2022
Thank you.
Is there an option for the connecting arrows? There doesn’t seem to be a way to adjust the text within a connecting arrow.
dvaliao
  • 4664 replies
  • August 3, 2022
Hey @Amanda15,
Sorry, but no. There is no way to edit text on a connecting arrow. The best workaround would be removing the text from the connector then manually adding editable text instead.
Amanda15
  • August 3, 2022
Thank you!
bennybenny
I have found a way to change the connecting arrow text size but it feels hacky. This works for me 100% of the time. I am using the Figma desktop app on Mac (116.2.4)
Steps:
  1. Click to make a regular text element and set the font size to the desired size (I chose medium, the default labels are tiny).
  2. Add a new label to the connecting arrows and start typing. The text size should be the same size as the text element you created.
  3. Delete the unneeded text element. You are only creating the text element to piggyback on the font change.
Brian29
  • August 15, 2022
Not true if you are a figma template creator 😕 . This connector label is part of a Figma flow chart template. I have no idea how they pulled it off. Because I don’t get any controls for text size on connectors
Brendan_Asselstine
This is great! Thank you.
Seems like it would be simple enough to add a text size dropdown to the toolbar? So strange.
