Resize frame without constraints
Tom_Coggia
Is there a way to resize a frame by entering its dimensions into the Design panel without causing the elements in the frame to attempt to adjust to the new size?
I realize that I can drag the boundaries of the frame directly while holding down the command key to achieve this, but typically I know the exact size I’m going for and it’s quicker and more precise just to punch in the number.
Best answer by avocadoneko
You can use this plugin!!
Figma
  • 4707 replies
  • February 3, 2021
No, it’s not possible. There is an ongoing feature suggestion for this: Keying size values on a frame while ignoring constraints
Meaghan
  • April 20, 2021
It is extremely frustrating to work on a frame that I cannot freely resize. I am developing UI and consistently find Figma horrible to use during the conceptualization process. This is such a minor feature that could speed up my work process tenfold. My solution thus far has been to copy the contents inside of the frame, delete them, resize the frame, and paste.
  • 4707 replies
  • April 22, 2021
You can use some resizing plugins to simplify the process.
Patricia3
  • February 22, 2022
Hi,
I saw this article with this solution:
Well, I recently discovered that by holding Ctrl while you drag and resize the artboard, it ignores element’s constraints set-ups. In addition to that if you hold Ctrl + Alt the resizing will be performed proportionally .
https://lautaroferreyro.com/figma-how-to-resize-frames-without-moving-objects-inside/
Christina_Irwin
Thank you so much for sharing this. Exactly what I needed to know! I appreciate you!
avocadoneko
Figma
  • October 12, 2023
THIS IS THE ANSWER! Thank you!!
  • January 23, 2024
This plugin has a very annoying limitation it seems: when you resize the frame, it will not keep the internal object centered, but resize the frame towards the top left corner. Is there any way to resize the frame while keeping the object centered? Thanks all!
  • 4707 replies
  • January 23, 2024
Use Center constraints? That’s their whole purpose.
  • January 23, 2024
Yes that’s what I thought. I put the constraints to center, but it still resizes the frame towards the top left, no matter what constrains I set. Does that not happen to you?
  • 4707 replies
  • January 24, 2024
Can you show an example? It’s unclear what you are resizing, how you are resizing and where you set the constraints.
