Remove intersection in lower layer only
Jared3
Hi All,
I am trying to create a new icon, based on an existing icon.
So, what i need is for the intersection of the two icons to be removed in only the lower icon. I’ve tried the Figma options such as Union, Subtract, Exclude, but it doesn’t get me what I want.
And it needs to be transparent (what I made green in the example could be either light or dark bg)
Can anyone help with how to do this in Figma please!
Best answer by Gleb
Subtract the rectangle with rounded corners shaped like the small icon from the bottom icon.
  • October 11, 2021
Jared3
  • October 11, 2021
Hi Gleb, thanks for the prompt reply.
but, I had already tried Subtract -it doesn’t work. Its results in only the intersection remaining.
Whats i did was select both objects, and then (from the Boolean options above) select Subtract.
Heres, a simplified version. Would be great if you could try it yourself:
  • October 11, 2021
What objects did you select? From your screenshots it seems like you tried subtracting the icon itself, and not the rectangle like I said. You need to subtract a solid rectangle. ◾ Don’t touch the smaller icon at all, it shouldn’t be a part of subtract.
Jared3
  • October 11, 2021
I’m a little confused, because, the subtract option doesn’t even appear unless multiple objects are selected.
And when you say a solid rectangle - do you mean, I need to create one? Currently there are no filled-in rectangles (because it needs to be transprent)
  • i added an update to my earlier post just as you were replying
  • October 11, 2021
Yes, you need to create one, or use the solid one you created before if you don’t need it. To subtract the rectangle from an icon, select the icon and a rectangle together, the option would appear.
Jared3
  • October 11, 2021
Still not working Im afraid.
I’ve just tried to make the file editable by anyone so I could show you. But the link its giving me is returning a File not Found:
https://www.figma.com/file/FPYDekEUTELNjx7FytDcO0/Subicon?node-id=0%3A1
What else do I need to do to share?
  • October 11, 2021
Set access to “Anyone with the link can view”.
Jared3
  • October 11, 2021
Yes, i had already set it to Anyone.
Screen Shot 2021-10-11 at 7.12.46 pm
the modal automatically activate the email field, as if I need to enter peoples email address
  • October 11, 2021
Try “can view” instead of “can edit”. Everyone would still be able to duplicate the file.
  • October 11, 2021
Also looks like your file is in the Starter team. I don’t think edit links are supported on the Starter plan, only individual invites via email. Not sure why you can even set it to that.
Anyway, here is the example: https://figma.fun/VakqLq
Jared3
  • October 11, 2021
I created another document, and now I can get to share.
would be appreciated if you are able to take a look, and see if you can do it.
thanks
*i removed the filled-in rectangle
Jared3
  • October 13, 2021
Hi @Gleb
thanks for your demo. Yes, it seems that is basically what I’m after. But I’ve tried to replicate it with my icon, but I can’t get the same result. I was thinking that I needed to select both the rear icon and the solid rectangle together and choose Subtract? But it doesn’t work. And also it creates a different type of icon (to your example) in the layers panel, so im not sure whats going wrong:
Here it is:
Figma – 12 Oct 21
Jared3
  • October 15, 2021
its ok, ive figured it out now. thank you
  • November 14, 2021
