Remove Component Status
Ada2
I have already found this issue but it was closed without a reply. There is no way of UN-component a component. Mainly to revert back to frame status. This is for the master component, not instances.
Is it just me or is there no way of doing this?
Best answer by tank666
tank666
  • 4870 replies
  • July 26, 2022
Ada2
  • July 27, 2022
I was using the same method, instance and detach, but it seems like just a workaround for smth that could be done with one shortcut.
I found a plugin, but it’s bit weird to use. But yes, that is exactly what I meant. Maybe a shortcut might be helpful in the future.
Thank you both!
