Re-publishing broken - doesn't recognize file is already published
  • September 24, 2021
  • 449 views
Christoph_Ono
I try to re-publish a file to community, with updates. I’ve done this plenty of times. Today, the “Publish file” form is completely empty. It should be pre-filled with the already published information (comment and duplication count, title, description, tags, creator…).
As I cannot tell whether this would actually re-publish the file or create a new community file, I will not go through with this. So I am blocked from posting updates. This forum won’t let me include links, so I can’t link to the community file, but it’s called “Bitcoin icon set”.
Seems like a bug. Would be fantastic if you could address this or let me know if something has changed about republishing files.
Best answer by Christoph_Ono
@wolfr thanks for the tip.
Looks like the issue resolved itself. Today, when the publish panel properly shows the right “Re-publish” option with all the info from the published file.
wolfr
  • Active Member
  • 21 replies
  • September 25, 2021
You should be able to post links in this forum using the hyperlink button:
Screen Shot 2021-09-25 at 15.03.13
Or simply paste a link in the text?
Seems like a strange situation. This seems like an bug/issue to ask support@figma.com about!
Christoph_Ono
  • September 27, 2021
  • October 27, 2021
