Question : how create a resizable "window" with constant frame size?
  • September 9, 2021
  • 7 replies
  • 1563 views
romuald
Hey there,
I’m looking for a way to create a frame (like the one you can put on you wall for real). I need this frame resizable, but I need to keep the frame width constant.
For example, if I create 2 stacked rectangles and apply a substract boolean operation, it works quite well.
But if I resize this frame, not only the inner area is resized but also the frame width itself. And I don’t want the size of the frame itself to be resized. Here is a probably clearer explanation :
Any idea how to do this? Thanks.
Best answer by tank666
You can duplicate my file:
Figma – 10 Sep 21
tank666
  • 4873 replies
  • September 9, 2021
You can achieve this in several ways.
Method 1:
  • Create a frame;
  • Add a stroke of the desired size.
Method 2:
  • Create a frame;
  • Create another frame inside the first one and resize it;
  • Set the “Left and right” and “Top and bottom” constraints for the inner frame.
romuald
  • 22 replies
  • September 10, 2021
Hi, thanks for the help.
  1. I see
  2. Seems interesting, by after some tries, I can’t figure how to make it work. Look.
Is there something I don’t do correctly ?
tank666
  • 4873 replies
You needed to set these constraints for the frame with white fill.
romuald
  • 22 replies
There is no such white frame. It’s an empty space made form a substract of 2 rectangles.
tank666
  • 4873 replies
Figma – 10 Sep 21
romuald
  • 22 replies
Fantastic 😍
Thanks a lot.
  • October 9, 2021
This topic was automatically closed after 30 days. New replies are no longer allowed.
